Airbag recall - document finally available here
Finally, the official recall paperwork was filed with NHTSA.
1. The issue is sharp bolts that can interfere with and damage the side-curtain airbags during deployment.
2. If your car was built after August 12, 2019, you are not affected.
3. Hyundai plans to notify owners in January. Your dealer may be able to get you in sooner
4. Hyundai's recall VIN checker still doesn't recognize my VIN as being affected, but I know it is. It takes time I guess.
PDF of the recall document: https://static.nhtsa.gov/odi/rcl/2019/RCLRPT-19V802-4806.PDF
PDF of NHTSA's letter to Hyundai: https://static.nhtsa.gov/odi/rcl/2019/RCAK-19V802-9266.pdf
The site did bring my Vin # up and I called a dealer and he also found it to be true. I was suppose to have it done yesterday but had to cancel Wed. do to a problem I had come up. Will have to call and set it back up. The service rep. told me it would take about an hoiur or so to fix .. have to remove the headliner
E
My VIN still makes the website report that everything is fine and there's no recall. It's OK though - they're not planning on notifying owners until January. If by then the website is still screwed-up then I'll be more concerned. Meanwhile, the dealership might catch it before then anyway.
I found mine on site "MyHydunai " and there too it said all was okay but then clicking on another link on that site if brought it up by my Vin. #
RickD
Did my airbag recall today, it took about 25 minutes. fast and EZ.
E
Thread Starter #7
What all did they have to do .. to make the fix..
It’s documented in the recall document I linked to. They’re putting a cover over the bolts
Did they have to do anything with headliner pull it back etc. The dealer I called said they had to remove the headliner to get to the screw and that concerned me. That sounded major to me.
