Stock Quad Exhaust Upgrade
sharkycsi
For me, this is a deal breaker. I live a long way from cities and towns, so I would need my spare tire. However, another solution you could look into would be the tips with a pipe extension for mounting. This would give us a non working exhaust which would give us the apperance of quad tips.(y)
C
Thread Starter #23
Definitely understand that! I saw a Korean version where they came off the end of the existing muffler with a pipe and over to the other side with just the tips so they did work as well just without the additional muffler.
Sent from my SM-G965U using Tapatalk
sharkycsi
That sounds like a good solution. If you see that option available, then get back with me. I think I could do that without hooking the pipe into the muffler, just because of the heat to the plastic and spare tire. Thanks.
C
Thread Starter #25
Not sure if this is 100% a solution but I saw another one I will try to find for you..
sharkycsi
You know, I think just having the tips with the "Y" at the end would work. I could get a muffler shop to mount it. Do you have access to the exhaust tips?
C
Thread Starter #27
Yes but only with the whole assembly unfortunately. The guy in Korea even tried finding just the tips for me used but no luck. Car is too new
C
Thread Starter #33
Where did you order the exhaust tip from?
Mine was the entire OEM assembly and I have a guy in Korea who gets the parts. The picture you quoted was something online where they used Mercedes AMG tips
Oh I didn't realize it was a AMG tip. The one that you purchase, are they using the same tip from the right side for the left?
C
Thread Starter #35
Yes the one in my original post and that I have is the same as the right side
One quick question. I looked underneath my Palisade and noticed the spare tire mounted to the left (driver's side) of the stock exhaust. There is very little room between the spare tire and the driver's side rear tire. Do you have to eliminate the spare tire in order for this to work?
Is that a small crack on the rear facia in the last photo?
