Hyundai Palisade SUSPENSION GEOMETRY AND TUNING
Front and rear suspension width was maximized on Palisade, for enhanced roll stiffness and stability. Tires are a generous 245/60R18 standard or an optional 245/50R20 size for stability, style and smooth ride comfort. Palisade front steering knuckles and rear carriers are made of aluminum, while front lower arms have been optimized and lightened via a new engineering design, resulting in reduced unsprung weight and improved responsiveness.
Palisade also achieves best-in-class body torsional rigidity through a variety of methods, including a multiple ring-shaped structure and hot-stamped door-ring parts that provide greater strength and rigidity. In addition, its torsional rigidity, when equipped with a sunroof, is nearly identical to versions without a sunroof.
