Here's Why You Shouldn’t Warm Up Your Car In The Winter
https://www.msn.com/en-us/Autos/own...dnt-warm-up-your-car-in-the-winter/ar-BBXLNoH
Why You Shouldn't Warm Up Your Car In The Winter
When it's frigid outside and you have to drive to some sort of destination, there's only one solution to fighting the ridiculous cold: Warm up the car. Just start it up a few minutes before hopping in, giving your cabin and your engine time to warm up before hitting the road. Plus, it's supposed to be good for the life of your engine, right?
Wrong! Warming up your car in winter before driving it is actually terrible for your engine. According to Popular Mechanics, driving your car right away is the fastest way to warm up your engine, and will actually prolong the life of your engine instead of letting it sit idly before driving. Answering the old question on whether you should warm up your car.
The reasoning has to do with how modern internal combustion engines work. By letting your car sit to warm up, it's actually putting extra fuel into the combustion chamber, which can get onto your cylinder walls. Because gasoline is an excellent solvent, too much on your cylinder walls can dissolve the oil that lubricates your cylinders, leading to shorter life on crucial components.
Driving Your Car Will Warm it Up Quicker than Idling
Of course, hopping into a cold car is never a fun task. Although driving your car will actually warm up your engine faster than idling, it still means driving for a period of time in a cold vehicle. And, it also means dealing with the frost on your car windows before they warm up. Fortunately, you can easily defrost your windows in 30 seconds with this simple car window defrosting trick.
Why Do People Warm Up Their Car?
Now if warming up your car in winter is actually terrible for your engine, why did people even do this in the first place? According to USA Today, this practices comes from the use of cars with carburetors—a fuel delivery system that preceded fuel injection that did require warming up beforehand. Some people would have to wait up to 10 minutes before even getting into a car, deeming it safe enough to drive with a warmed up engine. Nevertheless, cars and technology have drastically changed since the 1960s, which means this old practice is no longer required.
Instead, just give it a minute and start with an easy drive. Flooring it right away obviously isn't the solution, but easing yourself into a drive will help to warm your engine faster than you originally thought.
Haven't prepped your car for winter? Here's how to get your car winter ready, as well as the things you need in your winter car survival kit. Plus, check out how to change your wiper blades.
anthlover
I am sure that if it were bad for the car it would not be offered as a feature. Most things that are "bad" for car are some what prevented. The reset out of Snow, Sport Mode, Center Diff lock come to mind. I am sure there are others. Also many people going for a quick drive or not going to go very fast go much above idle causes its brief and stop and go, that's not supposed to be ideal for an engine either.
