Updates
Iversotr
Hi!
I keep seeing posts about map updates and software updates (May 15 seems to be the date). Can you please tell me where I can purchase the USB from? I would like the software update as well as the map update.
Thanks for your help!
sharkycsi
One note, the new update will require a 64 Gig ( or larger) flash drive for the new update. I purchased a 128 Gig drive on Amazon today for $26.10. Also, the update will take approximately an hour to install with your car running.
They say to use a 64 gb drive, but mine installed fine off a 32gb one
Gene
I purchased the update on the USB when it was first out. $25.00 figured I would use the USB as I wanted a new one.
It came on a 64gb USB and I reformatted dive now using as any I would have purchased for other files
sharkycsi
Hi Sax,
One more question. The map download guide states, "For vehicles with no SD card slot: A personal 64 GB USB (or larger) is needed. I have the Limited edition, but as far as I know I don't have a SD card slot. Does your model have a SD card slot?
McClendons
Hi Sax,
The Pallisade (all models) use USB vice SD Cards
Gene
Interesting, how large was the downloaded files that were installed on the flash drive?
The USB drive I received from them had a total 61,924,048,896 bytes of usable space. 42.9 gb used and 14.7 gb free
That doesn't mean the down load will be that big, you would have to check with someone who has downloaded the update.
The usb from them had txt files, encrypted txt files, and even an MDS file. It is loaded so you can do quick or full update
don't know if download includes all of that
Looks like saxman down loaded only in the mid twenties
Gene
Would be interesting to compare the files on the download compared to what Hyundai's mapcare usb I purchased had on it
CE55
FYI, I posted this also in the general forum discussion on Map update. I downloaded the new update yesterday and did the Quick install. The instructions recommended the Quick, and said they both install the same information.
The download and install went very well. I did not find any issues after install regarding media presets, etc. The instructions did say that all presets, and other map favorites could be erased during install. However, all of my saved information and media presets were intact. I will update further after getting a chance to fully utilize the new map.
sharkycsi
I too updated with the "Quick install" option without any problems so far. I did not like how it took my Siriusxm channels and reorganized them sequentially by lowest channel numbers down to the highest. Later, I am going to try to re-sort them how I like and see if they will stay.
