Pallisade won’t start
ricbwild
I have a 2020 Palisade that occasionally will not start when pushing the start button.
we have changed Fob batteries and tried pushing the start button with the fob itself as recommended by Hyundai Service.
Still doesn’t start at random times.
Has anyone else dealt with this ? Found a permanent solution?
Thx
BooBoo
Mine is a 2021 Palisade Calligraphy. When it decides to not start, nothing happens no matter what I do and the brake pedal gets stiff after the first attempt. When I get frustrated and open the door to go check the battery cables on the battery terminals, the act of opening the door makes everything come alive and reboot/reset. I actually got a picture of it coming back online and then it gave the message that the "Vehicle is On". What?!?!?! I beg to disagree!!!
It happened at the end of 2024, earlier this year and last night. It is way too intermittent for anyone to really be able to troubleshoot unless way more technical than we are.
At any rate, I didn't want you to think you were the only person out there.
Oh, yes... by any chance do you keep your wipers on automatic and do they randomly do a swipe about a mile-ish down the road? Not every time, but sometimes?
Update: I took the Palisade to an automotive shop for some work and it did it when they went to move it into the shop. Turns out the battery cable was loose. They tightened it. I'm expecting it to be resolved. I'll update again if there are issues again.
