- Messages
 - 1
- Likes
 - 0
I have imported USA car (2023 model) to another country. Obviously the navigation, HDA, Bluelink etc do not work here.
1. I noticed that Speed detection is not working, probably since it uses data from the navigation map.
2. The turn signal lane shift is also not working. Is this dependant on the HDA?
3. The HUD brightness is low even at night (checked all settings and no, I am not using polarised glass), then I noticed the HUD glass itself is not very transparent/ opaque. Is this the case?
4. The amber marker lights above front wheels stay lit on calligraphy? It doesn't on mine.
5. Smart lift gate when opening while staying behind is not giving out any warning tone. It does otherwise when you use keyfob or press manually. Any reason for this?
