Maintenance Milestones
Found this on the Telluride site, safe to say we can follow the same procedures
https://www.kiatelluride.org/threads/kia-telluride-vehicle-maintenance-milestones.376/
7,500 mi.
Replace
  • Rotate tires
  • Engine oil and oil filter
  • Climate control air filter
  • Fuel additives
Inspect
  • Brake fluid
  • Tire (pressure and tread wear)
  • Parking brake
  • Brake discs and pads
  • Air conditioner compressor/refrigerant
  • Air cleaner filter
  • Bolt and nuts on chassis and body
  • Vacuum hose
  • Battery condition
  • Steering gear rack, linkage and boots
  • Brake lines, hoses and connections
  • Suspension ball joints and mounting bolts
  • Exhaust system
15,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Fuel tank air filter
  • Brake fluid
  • Fuel lines, hoses and connections
  • Vacuum hose
  • Battery condition
  • Exhaust system
  • Parking brake
  • Drive shaft and boots
  • Vapor hose and fuel filler cap
22,500 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Exhaust system
  • Brake fluid
  • Parking brake
  • Vacuum hose
  • Battery condition
30,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Brake fluid
  • Parking brake
  • Cooling system
  • Vacuum hose
  • Battery condition
  • Exhaust system
37,500 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Rear axle oil (AWD)
  • Transfer case oil (AWD)
  • Brake fluid
  • Brake fluid
  • Exhaust system
  • Vacuum hose
  • Battery condition
45,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Brake fluid
  • Parking brake
  • Cooling system
  • Vacuum hose
  • Battery condition
  • Exhaust system
52,500 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Brake fluid
  • Parking brake
  • Vacuum hose
  • Battery condition
  • Exhaust system
60,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Drive belts
  • Valve clearance
  • Exhaust system
  • Vacuum hose
  • Battery condition
  • Brake fluid
  • Parking brake
  • Cooling system
67,500 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Exhaust system
  • Vacuum hose
  • Battery condition
  • Parking brake
  • Brake fluid
75,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Drive belts
  • Brake fluid
  • Parking brake
  • Cooling system
  • Vacuum hose
  • Battery condition
  • Exhaust system
82,500 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Vacuum hose
  • Battery condition
  • Exhaust system
  • Brake fluid
  • Parking brake
90,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Drive belts
  • Exhaust system
  • Vacuum hose
  • Battery condition
  • Cooling system
  • Parking brake
  • Brake fluid
97,500 mi.
Replace
  • Rotate tires
  • Spark plugs
  • Fuel additives
Inspect
  • Exhaust system
  • Vacuum hose
  • Battery condition
  • Parking brake
  • Brake fluid
105,000 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Drive belts
  • Cooling system
  • Parking brake
  • Brake fluid
  • Vacuum hose
  • Battery condition
  • Exhaust system
112,500 mi.
Replace
  • Rotate tires
  • Fuel additives
Inspect
  • Vacuum hose
  • Battery condition
  • Exhaust system
  • Parking brake
  • Brake fluid
CUMan
I don't expect that there are many folks on this forum who do their own maintenance on their new Palisades; however, there may be a few like me who prefer to do our own minor maintenance. Our Palisade just passed 4,900 miles as a result of a trip from the deep south (Alabama) to New Mexico earlier this month. Today I did the first oil change, after deciding that I would set a 5,000 mile threshold for this maintenance. I decided to post several comments that other self maintenance folks might find useful.
I have owned several Santa Fe's over the years and expected that the Palisade maintenance would be similar; however, there are several differences. For instance, the filter holder on most SF's is under the hood on top of the engine. The Palisade filter holder is underneath the engine close to the oil pan. The filter holder and drain plug are located underneath a plastic cover which must be moved aside to do the maintenance work. This cover is held in place with six screws (10mm in size). The filter holder can be removed with a 27mm ratchet to install the new filter. The filter part number is 26320-3CKB0. This filter is also used on the Kia Telluride. I bought my filter from a local Kia dealer which is located closer to home than any Hyundai dealer. The price for a filter should be in the $9-$10 range.
In the past I have done oil changes at 3000-4000 mile ranges using conventional motor oil. With the Palisade I decided to switch to synthetic oil and raised the change interval to 5,000. I used Mobil 1 5W-30 on today's change. The amount of oil needed for a change is 6.87 qts or 6 qts and 28 ounces.
Everything went well, but messy as always.
Mike
Thanks for the info @CUMan I also plan on doing my own maintenance.
I live about 100 miles from the nearest Hyundai dealer so I have my oil changed at another dealership. I use Mobil ! 5w 30. They check the air clearner filer etc. I have this display on the inst. panel that is telling me I have this many days etc. to get my service done . Being I have done that how do I clear that message that keeps popping up to service my Palisade..? Can anyone tell me how to clear that, or is this for some other type of service. Today was my 2nd. oil change an dI have 9700 miles on it. Thanks for any info.
In your instrument cluster settings. It's documented in the manual under service interval.
